are these the right parts for 3.73 ?
Old 04-04-2007, 10:07 PM
Sporty-X's Avatar
Just wondering before ordering if these parts are the right ones for changing my rear end gears ? :
1) Gear, Ring and Pinion, 3.73:1 Ratio, GM, 7.5 in./7.625 in., 3 Series, Set (at summit ref :SAG-G75373)
and also do i need these parts too to complete the install as i've seen i might use shims to properly put the gears in place
2) Ratech Complete Ring and Pinion Installation Kits
Ring and Pinion Installation Kit, Fits GM, 7.5 in./ 7.625 in., Differential, Kit
(ref SUMMIT : RAT-308TK)
Pierre
Sporty-X is offline
Old 04-05-2007, 08:39 AM
Doug 97SS's Avatar
What gears are in your car now? If they are 2.73's you are going to need a kit for the 2 series carrier. If you have 3.23's then you look good to go.
Also I would check with some of our sponsors for a complete gear setup. I bought mine through Thunder Racing. And it was complete. Don't forget the Posi additive too.
Doug 97SS is offline
Old 04-05-2007, 01:44 PM
Sporty-X's Avatar
Thnaks Doug. I have 3.23, my car is an A4.
I'm opened to any supported vendors as far as they can send their products overseas to my little country, with a DHL or FEDEX shipping. In fact, i would love knowing some more. I will have to check with Thunder Racing
Sporty-X is offline
Old 04-05-2007, 07:25 PM
Doug 97SS's Avatar
Ahh..gotcha...I never look at the location. My fault. So Summit may be your only choice to have the parts shipped by.
Now back to the 3.23 gears what you listed will work perfectly for your application. Don't forget to reprogram the PCM for the new ratio too. At 70mph I "THINK" you will be turning around 2300rpm or 2500rpm....Not sure though. THere is a calculator for that. But the car will be fun for you. Good luck!
Old 04-06-2007, 06:43 AM
Sporty-X's Avatar
thanks for your help Doug
Sporty-X is offline
10-31-2016 11:09 AM
novaiiman
05-15-2016 11:36 AM
RUENUF
03-13-2016 03:39 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Quick Reply: are these the right parts for 3.73 ?
