differential girdle...info needed
Gonna be swapping on a differential cover here pretty soon. Got some basic questions even after a search...figure i'll try to get it all in one thread. plan to do an install guide when i finish.
Gear oil….what weight and any particular brand?? I already know I need the LSD additive. Also…how much fluid(aprox)?? i'm pretty sure the additive is 4oz.
Gasket….the cover is used, so I need to get a gasket. Or should I just use RTV? Or both? And if so…what brand/kind.
Stud Kit…pretty sure I’m gonna get this. Its $20 at TR…I figure why not. Any input?
torque specs…for the stud kit, I believe it’s 10# for the stud, 65# for the nut. And I know the preload bolts are 5# (60 in-lb), and the cover bolts are 22#. Are all those correct?
Any particular tricks I should be aware of?
Thanks guys
Thanks guys
Gear oil: I used 80w-90, and a little less than 2 quarts will fill it. Put the additive in first.
Gasket: Used a cork/composition gasket that was a couple dollars at the local store. It was a cheapo one, but is working great. Didn't need RTV.
Stud kit: why not.
Torque: no idea here since I didnt put a girdle on mine.
No real tricks that i encountered. It's straight forward, easy to do. Just be ready for oil to come spilling out right away.
Stud kit: why not.
well turns out iin order to install the MAC girdle with the ARP stud kit, you have to clearance the inside edge of the cover. was a pain in the ***...considering i already had the gasket and RTV all applied.
here are the pics of the clearancing i did. i think i need to knock down a TINY bit more on one of the spots for good clearance (granted i tested it without a gasket...but i want to be safe)
stud kit went in easy..no major problems, other than having to use an in-lbs torque wrench to tighten down the studs...my standard torque wrench didn't go down to 10#...so i had to do 120 in-lbs. not a big deal since i need that small of a torque wrench anyway to do the preload bolts.
haha...combo of things.
started with a hand file.
moved on to a bench grinder
then finished it off with another file
and then just smoothed it out with some sanding
no kidding.
and i test fit it and it seemed to lay flush on the differential housing, without a gasket. but i think i couls see that the studs were still touching slightly. gonna grind down just a bit more to make sure.
ugh...
good thing is that the trans is out for a clutch refresh...so it's not like it's costing me drive time
ugh...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
