True Dual Exhaust
Old Mar 4, 2003 | 11:51 PM
tainted's Avatar
True Dual Exhaust
What is it? Is the set up very hard? What's needed in order to run it? All replies are appreciated guys.
-Matt
Old Mar 5, 2003 | 12:00 AM
59apache's Avatar
order the kit from dr. gas, my buddy had it on his car for under 450 bucks, great kit, has an x-pipe, sounded awesome
Old Mar 5, 2003 | 12:09 AM
stik6shift98's Avatar
i would go to an exhaust shop...prob one that deals with camaros and have them do a custom true dual setup.....
Old Mar 5, 2003 | 12:11 AM
GrdLockV6's Avatar
What is it?
It's exhaust that has two pipes all the way to the exit. On our cars stock, they have a y-pipe which merges the two pipes from the headers into a single pipe. True dual goes from the headers, into an x or h-pipe (usually) and continues going back in two pipes until the exit, therefore less restrictive.
Yes, the Dr. Gas kit will be nice. You still have to find a shop or person willing to do custom work though, as it's not a direct bolt up. You'll need two mufflers, unless you want to run straight pipes which I don't recommend. The bullit mufflers are nice, as they're small, fit well, and sound nice. Mufflers are your choice though. If you want the exhaust to exit out the rear of the car it'll cost more since they'll hafta fabricate you an over-axle setup with two pipes. If you want it cheaper you can just dump it under the car. It's all up to you.
Firechicken350
Jun 6, 2015 11:25 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Queens94z28
Nov 20, 2014 06:03 PM
guionM
9
Aug 29, 2002 01:48 PM
