rear end and suspension question
Old Feb 26, 2003 | 01:56 PM
vhgjk123's Avatar
If i were to replace the rear end with a 12 bolt would that interfere with any suspension mods. By this i mean what if any suspension mods i put on now would i have to take off or replace if i got a 12 bolt put on later? Do any of the suspension mods connect to the rear end. I dont want to buy suspension stuff now only to find out i would have to buy it again when i get a new rear end. Thanks
Old Feb 26, 2003 | 02:06 PM
GrdLockV6's Avatar
Naw, everything fits up to a 12 bolt just fine. You'll need a sway bar mount kit, which is like $50, cause the sway bar doesn't mount up to the Moser without it. Some aftermarket torque arms have be ground in a few places to fit, but any decent shop won't have a problem doing it. Other then that everything else should be no problem. I just got my Moser on and the only thing I needed was the 19mm sway bar mount kit, BMR makes it. I still got my factory torque arm though. Shocks, springs, LCA's, all that is just fine.
EDIT: But to answer the question, there's no suspension mod that you can put on now that won't work on the rear end with a little work or $50 or so.
Old Feb 26, 2003 | 03:55 PM
vhgjk123's Avatar
Thank you for the reply but i dont think you quite got the jist of what i am asking. I mean is there a mod that if i put on now i would have to take it off to fit on the new rear end? Do any suspension mods attach to the rear end so if i put on something that does attach to the rear end now and later i bought a new rear end would i have to buy a new suspension piece sine the other one is attached to the old rear end. I hope that makes a little more sense. I am having trouble expressing myself on this concern sorry
Old Feb 26, 2003 | 09:49 PM
2002Z28SSConv's Avatar
Yes there is. If you put lowering springs on, lower control arm relocation brackets are recommended. If you select the bolt-on brackets you'll be able to transfer them unless you weld them on too. Of course any part that is welded onto the rear end is permanent. Otherwise everything will transfer with little or no modification.
Old Feb 27, 2003 | 11:15 AM
vhgjk123's Avatar
so just the springs and relocation brackets are the only suspension mods that could be welded to the rear end?
Old Feb 27, 2003 | 11:21 AM
GrdLockV6's Avatar
Just the relocation brackets, springs aren't welded to anything. Just be sure you get bolt on parts and don't weld them on and you'll be ok.
Old Feb 27, 2003 | 12:54 PM
stik6shift00's Avatar
I would use your money for more mods now, just use nitto's and i doubt you'll break it. and if you do 90% of the time you break the gears, you can get new ones installed for under 200.
Old Feb 27, 2003 | 04:28 PM
stik6shift93's Avatar
Pretty much everything, lca, panhard rod, torque arm........is interchangable between the stock 10 bolt and a moser 12
Old Feb 28, 2003 | 09:35 AM
poniekiller's Avatar
If you have a lot of power, I wouldn't go with bolt-in LCA brackets at all. You can't drive home without a lower control arm, and the tow bill will cost you what another set of weld-ins will cost you.
Old Feb 28, 2003 | 09:43 AM
2002 NBM Bird's Avatar
Where do you go for installed gears for $200
Gears alone are $200, installation is another $200 at least, unless you want to do it yourself, but that installation is no walk in the park.
Old Feb 28, 2003 | 10:07 AM
We can actually get gears installed for $150.....It's good to know people.
Old Feb 28, 2003 | 10:37 AM
too bad I don't know anyone that well
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
