My turn signal is acting weird!
Old Feb 27, 2003 | 08:26 AM
DaveGrun's Avatar
This just started happening a day ago. Whenever i put my left turn signal on, instead of the arrow signal on the dashboard blinking, it just comes up as a solid arrow. But my right signal works fine. What is wrong?
Old Feb 27, 2003 | 08:42 AM
DougS's Avatar
It means that a bulb has burned out on the left side of your car.
Old Feb 27, 2003 | 08:48 AM
DaveGrun's Avatar
You mean the back turn signal?
Old Feb 27, 2003 | 09:49 AM
psychocabbage's Avatar
could be front or back.. turn car on while on a flat level surface.. put in neutral(M6) or park(A4), turn on turn signal.. walk around car.. see if any light is not working.. if that doesnt work, turn on your hazzards... so you can compare right and left.. NOTE: sometimes the blinker for the hazzards will work on a turn signal but the turn signal wont.. odd but happens on some cars so I thought I would mention it..
stangspank
Nov 13, 2015 01:02 PM
reww86
Apr 27, 2015 05:17 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
