Air Pump Removal
Old Feb 21, 2003 | 09:02 AM
petegz28's Avatar
Air Pump Removal
Shoudl I remove my air pump off my 99Z? It only leaves the garage on nice dry days so it is not a daily driver. I have heard there are lots of benfits to removing the air pump. What does everyone think?
Black 99 Z28
SLP Cold Air Induction
SLP Air Lid
SLP 3" Stainless Cat-Back Exhaust
K&N Air Filter
K&N Oil Filter
Gatorback Serpintine belt
Old Feb 21, 2003 | 09:20 AM
PhantomTA's Avatar
Moderator
the only thing you get by removing it is you lose like 8lbs if you take everything off
Old Feb 21, 2003 | 09:22 AM
petegz28's Avatar
Air Pump
Will it clean up the engine compartment as well?
Old Feb 21, 2003 | 10:02 AM
rncotton's Avatar
Will it throw a code?
Old Feb 21, 2003 | 06:08 PM
JaysZ's Avatar
Here's a nice little article at ls1camaro.net about removing your AIR system:
http://www.ls1camaro.net/sections.ph...icle&artid=70.
I'm going to do it one day just to clean things up. It says you won't throw any codes.
Old Feb 21, 2003 | 09:03 PM
PhantomTA's Avatar
Moderator
itl throw a code but not right away
Old Feb 22, 2003 | 10:11 AM
danziger's Avatar
Unhappy
It will throw a code and cause your cats to fail prematurely. Cleans up the engine compartment and saves weight. Might as well toss the EGR too...
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
