siren sound at rear??????
i was on the highway and after 170 miles it started and after 400 miles it got to the point it sounded like a siren was going in the back of the car. when its sitting still, its silent but once u start driving the car its LOUD. at low speeds it makes a click (like in the driveway). this really makes me mad cuz i've only had the car for a week.
thanks for the help,
mike
mike
what year car and what kinda car?
I had to have my Gears Replaced at 23,000 mi. they just started to make a clicking noise so the dealer replaced the gears and from what i here it is commen problem.
If you experienced a bad case of wheel hop during heavy accelleration, then have noises coming from the rear end, I'd have the car towed in to have the gears checked out. I've had catastrofic gear failures before while the car was in motion. It's not something I'd recommend as a 'must do' experience.
The noise isn't going away. It will only be a matter of time before it completely blows.
well they called me and told me it was fixed (the bearings and seals they said was jacked up). i got out of the dealership and drove for about 10 minutes and it started again
. i can't convince them that its the gears though. wut do i do????
thanks,
mike
. i can't convince them that its the gears though. wut do i do????thanks,
mike
If they are sure it's not the gears, then they need to fix whatever else they think the problem is, don't they? If the noise is still there, the problem is still there. Be a pain in the ****. Don't be nice. Be insistant that it get fixed right. Otherwise they'll walk all over you and you'll end up paying for it once the warranty is up.
(same as urs so it makes me think) just hit 26,000 miles
thank god for warrenty.
