Gtech Competition HP/TQ
Supposing I entered the exact correct vehicle weight (even including me in the drivers seat) (gvwr -180*3), would the Gtech's 309hp and 338 lb/ft of torque at the rear wheels be pretty accurate?
I was just messin around on my way home today with it (i got an awesome 2.9 60ft and 6.0 0-60 run with those hp/tq numbers!!
(I guess i cant hook in the cold weather)
anyway, I was curious to know if you guys that have the Gtech have ever gotten your car dynoed and compared it to the gtech's numbers.
btw, it's a getch pro competition
-Jason
(I guess i cant hook in the cold weather)anyway, I was curious to know if you guys that have the Gtech have ever gotten your car dynoed and compared it to the gtech's numbers.
-Jason
You wouldn't be able to run the Gtech while the car was on the dyno, since it is an accelerometer, it wouldn't get a reading unless the car is moving...uinless you meant had dyno numbers already and compared them to what they ran with the gtech. In that case ignore me
I've run mine at the track and it is pretty close, but the MPH is usually high.
Scott
Scott
gtec
Hey
I have the original g-tec . I heard the new comp g-tec is better Thats hp figure seesm right there. I also have a tazzo. I have found the tazzo to be a very accurate tool for measuring performance right out of the box.
www.tazzo.com is the website.
By the way it alot cheaper than the new gtec and also does 1/8 mile and 60 ft times along withthe hp readings.
Btchslp
Aug 19, 2002 07:00 PM
