Casting differences between LS1 and LS6 heads
Old Feb 27, 2003 | 03:52 PM
WJH'sFormula's Avatar
My dad was asking me this question while pondering possible setups for his 02 Z and quite frankly I have no idea.
I know that the LS6 castings flow better, but that's about it!
TIA
Old Feb 27, 2003 | 05:09 PM
stik6shift93's Avatar
I can't tell you where the exact differences are but I can tell you that instead of spending money on the ls6 heads take that and have you ls1 heads ported out, you'll have a had that flows more than the ls6, for the same price.
Old Feb 27, 2003 | 06:19 PM
money is not a big issue here....
also, either way, the heads will be ported
I'm just trying to figure out what differentiates the two...
Old Feb 28, 2003 | 06:33 AM
NC Dude's Avatar
LS1
12559853 (99-00)
12564241 (01-03)
Combustion Chamber Volume:...........66.67 cc
Compression Ratio:............................10.1:1
Intake Port Volume:............................200 cc
Exhaust Port Volume:..........................70 cc
LS6
12564243 (01-03)
Combustion Chamber Volume:............64.45 cc
Compression Ratio..............................10.5:1
Intake Port Volume:............................210 cc
Exhaust Port Volume:.........................75 cc
All castings have 2.00" Intake and 1.55" Exhaust Valves.
Old Feb 28, 2003 | 09:32 AM
Thumbs up
thanks! thats exactly what i needed to know
Old Feb 28, 2003 | 10:14 AM
If they're going to be ported either way then just go with the ls6 castings, I believe you can get another 20cfm or so out of them over a ls1 head.
Old Feb 28, 2003 | 01:34 PM
XKnightRider's Avatar
The other differences are that the LS6 heads have D-shaped exhaust ports, LS1's are oval/round. Supposedly the D's flow better, the LS6 stock heads have lighter valves and retainers. But the cost of the heads, port job everything is more expensive. If money is no object, get the LS6's. If you are going all motor, no pwer adders later these heads rock!
Old Feb 28, 2003 | 10:46 PM
danno02SS's Avatar
I'm thinking of going TT (not so near future). I was also planning to get PACEs LS1 to LS6 conversion kit (heads and cam) by summer. Given that the LS6 CR is already 10.5 should I just keep my LS1 heads and just port them to flow better? Thanks.
Old Mar 1, 2003 | 09:29 AM
My84Z's Avatar
dano if you plan on the tt route i would wait till your ready for the tt and get some nice 6.0 heads it will lower the compression and flow great.
pimpss96
Feb 12, 2015 01:28 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
