My Brakes make a grinding noise!
When i use the brakes, there is a grinding noise coming from the front right brake. Could this just mean my pad is worn out, or is it something else?
Most likely the pads, just take the wheel off and check the pads. My brakes also need to be replaced soon. I've heard many people saying the stock rotors are crap although I can't really complain about mine. After 55K miles they're just worn down (Isn't that normal ?)... Are AutoZone rotors better than the orig. equipment ??? 100 a pair sounds like a good deal to me.... the pads should be around 30 - 40 ...
NewsBot
Dec 21, 2014 06:55 PM
