LS6 to LS1 intake manifold swap...
Old Mar 4, 2003 | 10:34 PM
Trey395's Avatar
Can someone tell me if swapping my LS6 intake on my 2002 Z28 to my LS1 intake off my 1999 C5 will set any codes on the '02? I know going from the LS1 to the LS6 on the vette is ok, but I was a little unsure on going backwards on the Z28.
Thanks in advance!
Old Mar 4, 2003 | 11:02 PM
stik6shift98's Avatar
i dont think it will....why are u doing that???
wanna sell me your ls6 intake????
Old Mar 4, 2003 | 11:14 PM
Trey395's Avatar
C5 is getting the LS6 intake...
that is, assuming the Z28 can take the swap.
Old Mar 4, 2003 | 11:20 PM
danz28123's Avatar
It seems to me that it would be much easier and smarter to leave the ls6 intake manifold on the z28 and buying a new one for the vette. It will be 1/2 the time, you won't lose power on the z, and ls6 intake manifolds aren't that expensive.
Old Mar 5, 2003 | 02:37 AM
bunker's Avatar
better yet get the C5R intake, I was told it flows more than both regular ls1/ls6 intakes? My buddy just got a c5r intake whe're doing cam/intake & lots of other things
Old Mar 5, 2003 | 08:37 AM
Camarocks's Avatar
I don't know much about how intakes are measured, is it how many cfm they handle? How much better is the LS6 intake than the LS1?
Old Mar 5, 2003 | 09:20 AM
bbentley40's Avatar
Where can you get a C5R intake? And would it work on a camaro?
Old Mar 5, 2003 | 02:08 PM
Trey395's Avatar
I take it then that nobody actually knows the answer to my question?
Old Mar 5, 2003 | 05:42 PM
rick99ws6's Avatar
the only thing that could cause problems is if the LS1 intake had EGR, but the Vette LS1 intake doesn't have that anyway, so you should be ok
Old Mar 5, 2003 | 06:22 PM
Capn Pete's Avatar
Exclamation
Well, the '01 & '02 LS1's are supposed to have the EGR system removed, so that shouldn't be a problem, and otherwise, all the intake does is direct the air into the cylinders (right ), so I don't see how it would set any codes? It's no different than putting a bigger, better flowing throttle body on. I guess the only "difference" will be that it will flow "x" # of cfm less, so the MAFS will sense less air flowing through, but I don't think it'll set a code............could be wrong though.
Old Mar 6, 2003 | 10:11 AM
Trey395's Avatar
Capn/rick - thanks for the info guys. The EGR was what I was worried about most. I could see the computer really throwing fits if it was there on one and not the other. It sounds like I'm safe though...
HarleyZ28
Oct 5, 2015 06:23 AM
birdblack
Dec 30, 2014 06:59 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
