Pro 5.0 or B&M Ripper
Old Feb 26, 2003 | 10:58 PM
Ferocity02's Avatar
Well........I can't choose between the two I heard the B&M is quieter than the 5.0, which is one of my concerns. But I haven't heard anything about the 2-3 shift for the B&M Is it easy? I heard the 5.0 makes it really easy. I'm doing street driving, probably will never go to the strip. Also the B&M is is a little cheaper
BTW, I have a 99 Z28
One more thing, the B&M says it is adjustable. Does it have to be precisely adjusted because I have no idea how to do such a thing.
Old Feb 27, 2003 | 12:39 PM
TA76's Avatar
Hi, I can't speak for the 5.0 but I loved the B&M in my 6spd Z! Big improvement over the stock unit but took some getting used to at first. I'd wouldn't have a 6spd without one!
Old Feb 27, 2003 | 12:50 PM
stik6shift00's Avatar
I have the pro 5.0 and i like it, but i have the shorter throw for it, takes some time to get used, but im used to it, i think it makes a awesome sound when you put into diffrent gears.
Old Feb 27, 2003 | 05:32 PM
stik6shift93's Avatar
5.0 here too, great shifter. Having driven both I go with the 5.0.
Old Feb 27, 2003 | 07:41 PM
1badLS1M6's Avatar
I'm in need of opinions too. I can get a B & M Ripper for $159 shipped, or a Pro 5.0 for $179 plus shipping. Is the 5.0 shorter? What should I get??
Chris
Old Feb 27, 2003 | 07:59 PM
96SFLZ's Avatar
If you're more into racing then go with the Pro 5.0, you'll rarely miss a gear with it. If you just want a shifter that's nicer and feels better (a lot better) than the stock unit, go with the B&M. That's just kinda how I would sum it up.
I don't think the Pro 5.0 is much, if any shorter than the B&M but the nice thing about it is that you can replace the handle with a shorter one (like a LSS) or you can cut an inch or so off of the "stock" Pro 5.0 handle, which is what I did and I love it, it's perfect IMO.
Old Feb 27, 2003 | 08:42 PM
Ferocity02's Avatar
Everyone says these shifters are louder than the stock. How are they louder? Do they just vibrate more?
And also, how you you "adjust" the B&M Ripper? It says its adjustable and I'm not quite sure how to do it? Is is hard?
Old Feb 27, 2003 | 08:59 PM
98whiteZ28's Avatar
Well i have driven both, and i personaly liked the B&M, nice shift from 2 to 3. And when they say adjusable, they come with these washers that fit in the grooves of the shifter base that allow you to "fine tune" the shifter if needed. I had no need to adjust mine so i just used the "stock washers" that set it in like the stock shifter was so, i dont know why you'd need to adjust it. But i loved it, it shortens throw but almost half, but then the next day i total'd my Z. And now have a 99 SS with the Hurst short throw, with a Lou's short stick, and its a pretty tight shift i love it.
Old Feb 27, 2003 | 09:05 PM
96SFLZ's Avatar
The only thing that's adjustable is the stops...and the Pro 5.0 has adjustable stops too. They are just there to prevent over-travel if you want to "use" them. IOW, you can make the travel between gears a little shorter by moving the stops in (towards the shifter). If you move them too far in though, it won't go into gear, or you might move them just a little too far and it'll go in but it'll pop out of gear after a few seconds (or longer)...you get the idea.
Yes, the Pro 5.0 is "louder" than stock...noisier would be a better word. It just makes a little noise (no big deal), compared to the stock one which doesn't really make any noise.
Edit: Oh yeah, 98 white is right. The B&M is kinda adjustable in that you can move it (using the washers) a little forward, a little back or use the stock location. I forgot about that...I used the stock location, on my '96 (had the B&M). The Pro 5.0 is not "adjustable" in this way.
Old Feb 27, 2003 | 10:15 PM
Ferocity02's Avatar
Thanks man, that clears up everything.
Old Feb 27, 2003 | 11:44 PM
Josh'95Z28conv's Avatar
My vote goes for the pro 5.0! I have a B&M, and I think it sucks. I had one on another car, and loved it. The one for the f body dont even compare though. I'm gonna sell it and get the 5.0. From what Ive heard, the through is much shorter. IMO, the B&M still has a long through, and the 2-3 shift still sucks. Im gonna put it in the for sale sectoin when I get money for the new shifter. How's that for a testamonial.
Old Feb 28, 2003 | 08:38 PM
Ferocity02's Avatar
Biased
How much you selling it for?
Old Mar 1, 2003 | 03:21 PM
Ferocity02 Biased
email me if your interested in buying it. joshveith@yahoo.com
No, Im not biased. In the past I have been very pleased with B&M, but I want to give the Pro 5.0 a try.
Old Mar 2, 2003 | 01:05 AM
stik6shift98's Avatar
get a bm ripper i had both and now have ripper because 5.0 doesnt feel as smooth, comes loose, and makes a lotta noise
Old Mar 2, 2003 | 03:53 PM
Ferocity02's Avatar
Well this didn't help at all. I'll guess I will go for the cheaper one, the B&M Ripper.
