Rear End
Old Feb 23, 2003 | 04:27 PM
toddfather's Avatar
Rear End
HOW WOULD I FIND OUT THE GEAR RATIO FOR THE REAR END OF MY 98 Z28.AS FAR AS I KNOW IT IS STOCK.I CHANGED MY MY TIRE SIZE AND MY POWER PROGRAMMER WANTS TO KNOW GEAR RATIOS?
Old Feb 23, 2003 | 05:26 PM
SpecForceZ28's Avatar
AUTOMATIC TRANSMISSION OR MANUAL TRANSMISSION?
Old Feb 23, 2003 | 06:14 PM
toddfather's Avatar
automatic
Old Feb 23, 2003 | 06:42 PM
In that case, if you know its stock, then it will either be 2.73 gears, or 3.23 gears. other than that i dont know much, sorry. but you will most likely have one of those two gears.
Old Feb 23, 2003 | 06:44 PM
toddfather's Avatar
THANKS, I WAS WAY OFF.
Old Feb 23, 2003 | 07:25 PM
#7's Avatar
Hey,Specforce how about 99 w/M6?
Old Feb 23, 2003 | 08:01 PM
Capn Pete's Avatar
Exclamation
Here's the breakdown guys:
  • 2.73's: come standard with the A4 (code GU2)
  • 3.23's: are an option for A4's (code GU5)
  • 3.42's: are standard and non-optional for the M6 (code GU6)
If you look on the door sticker at the list of codes, you should find either GU2 or GU5 if your car's an auto, or GU6 if it's a standard. This tells you what gears the car has (as long as they're still stock).
HTH.
Old Feb 24, 2003 | 09:07 PM
#7's Avatar
Originally posted by Capn Pete
[*]3.42's: are standard and non-optional for the M6 (code GU6)[/list]
99 M6 w/3.42 yes,but could you please tell me if it has Posi or LSD?
Thankx,T.
Old Feb 24, 2003 | 09:35 PM
Capn Pete's Avatar
Arrow
A posi (short for "Posi-trac") is a form of a Limited Slip Differential (LSD). The LSD in the 4th gens is a Torsen (I think?! ) which is like a posi, but it's not a true "posi". They all work under the same principle though --- one wheel can be held, or turn slower than the other (ie: while cornering) but otherwise the power wants to hit both wheels equally. I think there are actually 2 (or 3??) styles of limited slip's for the 4th gens, but I don't know all the specs on them.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
