throttle body bump stop mod
Old Jan 28, 2004 | 06:49 PM
prohunter4's Avatar
can you use a voltmeter to tell you when you have the optimum opening when doing this mod.i thought i saw this on an earlier post.thanks
Old Jan 28, 2004 | 08:58 PM
chris mac's Avatar
it's better to use a scan tool. that way you're going by what the pcm actually "sees".
good luck
mac
Old Jan 28, 2004 | 09:04 PM
AL SS590 M6's Avatar
Moderator
Re: throttle body bump stop mod
Yes a volt meter will work fine. Done 2 that way so far.
Scan tool is a better way to go "if you have one".
Old Jan 29, 2004 | 11:51 AM
NEWBIE T/A's Avatar
Lightbulb 4.7 Volts is the max number, if I remember correctly.
I think the guy that did mine went w/ 4.67 , or close to it.
If you grind (go) over this limit, you get the joy & thrill of attempting to add metal back on and a SES light for your trouble !
Britt
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
RedLineRev
Jan 23, 2003 03:51 PM
