magnaflow catback people inside
Old Jan 20, 2004 | 07:34 PM
ShayTal's Avatar
those of you with the Z (not SS), how much HP did you gain by installing the magnaflow catback (15684)
Old Jan 20, 2004 | 09:43 PM
teke184's Avatar
on an otherwise bolt on car, i would say a solid 10hp...you really can't expect too much more than that...
Old Jan 20, 2004 | 10:39 PM
2K2-Z28's Avatar
I tell you what.........
I've never dynoed my car, but after the install, there was a much greater throttle response and enough horsepower gain to tell a NOTICEABLE difference. I have loved mine since I got it.
Old Jan 21, 2004 | 09:10 AM
ShayTal's Avatar
thanks guys,
i am going to get my from ebay, how much should i expect to pay for installation ?
Old Jan 21, 2004 | 10:17 AM
lastZ's Avatar
expect to pay nothing....install it yourself...takes an hour 2 at the most. good cat back system you will like it!
Old Jan 21, 2004 | 10:18 AM
teke184's Avatar
yeah you "should" be able to install it yourself using clamps. but if you want it welded up...probably about an hour of work at a shop...so maybe $50-75 depending
Old Jan 21, 2004 | 11:48 AM
Gloveperson's Avatar
I don't think just adding a cat-back to a stock car will add too much power. Install some LTs and you might see a 10 RWHP jump, but I would never expect much otherwise. I would highly recommend the system, it sounds really good.
Old Jan 21, 2004 | 12:21 PM
ShaneS's Avatar
This is incorrect. You should see around 10+rwhp from just a catback - if you're going from a non-SS/WS6 LS1 f-body. A little less if you have an SS or WS6 exhaust. You should see at least that much *more* again if you add longtubes...
Good luck!
Shane
Quickss96
Jan 29, 2016 05:56 PM
HibachiZ28
Nov 6, 2015 12:53 AM
JJOHNROE
Sep 8, 2015 05:39 PM
Nickster 7
Aug 27, 2015 10:12 PM
