TA Headlights
Old Jan 24, 2004 | 02:25 PM
RxNupe's Avatar
Lightbulb TA Headlights
I have replaced my right-side head light twice this month. Could there be an electrical problem causing the light to blow? Is there a brand other than Sylvania that makes replacement head lights?
Old Jan 24, 2004 | 03:44 PM
nikkev's Avatar
Be careful putting the new bulbs in.If you touch the bulb then the oil from your finger can heat up and cause the bulb to blow.Just an idea...
Old Jan 24, 2004 | 09:31 PM
rncotton's Avatar
nikkev, the Firebird headlights are a sealed beam design ... I.E. we replace the entire assembly, glass and all. Unlike the Camaro where you replace just the actual bulb.
As for the headlamp blowing out. Well, there could be a problem somewhere, or you could have just gotten a bad replacement lamp.
If you still happen to have the receipt, I would suggest going back to the store and complaining that the lamp you bought only lasted XX weeks.
If it blows again, then you certainly have an electrical issue.
Old Feb 18, 2004 | 05:19 PM
RxNupe's Avatar
Angry
Ok....I have replaced by right headlight 4 times since December. What tha hell could be going on. Why are my headlights blowing. Anybody else with this problem?
Old Feb 19, 2004 | 08:50 AM
rncotton's Avatar
It's an '02? Take it to the dealer, along with your headlight receipts, and make them fix it under warranty.
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
