Water pump gaskets
Old Jan 19, 2004 | 05:08 PM
lws99's Avatar
Water pump gaskets
My 99 SS only has 26,000 miles on it and I discovered that I have a slow leak on the driver's side gasket. I got two new gaskets and I wanted to know if it would be ok to add a little RTV around the "O" rings on the metal gasket? I don't want to do this job on a regular basis. Thanks all.
Old Jan 19, 2004 | 06:03 PM
mitchntx's Avatar
That shouldn't be necessary. The gaskets you have are very good gaskets.
I believe you have paper gaskets on your car now. At least I think '99s still had them. What a PITA to remove.
Make sure you get it all off before going back. I used a brass wire wheel on a drill motor to get it all clean.
Good luck and don't over tighten ....
Old Jan 19, 2004 | 07:01 PM
lws99's Avatar
99 & up use metal gaskets.
Old Jan 19, 2004 | 08:33 PM
mitchntx's Avatar
Well, there you go ...
Old Jan 19, 2004 | 08:46 PM
Ferocity02's Avatar
They are metal, and dont need any RTV. I changed mine when I did the cam swap and I could tell that they had gone bad, maybe leaking some coolant I don't know, all better now.
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Queens94z28
Dec 20, 2014 09:11 PM
