weigh in here
Old Jan 23, 2004 | 04:07 PM
mullettour's Avatar
weigh in here
Just put my car on the scales to see how much it weighs cause I've been curious about it. Turns out it weighs 3350lbs.
Seems kinda light but I don't really know what camaros usually weigh in at. Its a stripper car and had an empty tank. Anyone else weighed their car can tell me if that sounds right. Also I wasn't in the car when it was weighed.
Thanks,
Josh
Old Jan 23, 2004 | 04:13 PM
z28chrizz's Avatar
Im 3660 with me and a half tank. No lightening done. Im 230, so that leaves 3430 for the car + 8 gallons of gas. Mine is a typical mid option T top car.
Old Jan 23, 2004 | 04:38 PM
mullettour's Avatar
Cool. I just seemed to remember reading a post not to long ago of a guy who weighed his car and it was 3800 lbs or something like that.
Old Jan 23, 2004 | 04:47 PM
chpmnsws6's Avatar
probly a full weight car with bottle and cage
Old Jan 23, 2004 | 09:45 PM
FLIPPINZ28's Avatar
i weighed mine in at 3280 with the ac gone carpet padding and swaybar. without me in it. with me in it 3460 i weigh 180
Old Jan 23, 2004 | 11:02 PM
94ZRiCeKiLr's Avatar
mine is 3400 pounds even without driver and about 1/4 tank of gas. it has EVERY option except ground effects and was weighed with NO weight reduction.
Old Jan 23, 2004 | 11:36 PM
AL SS590 M6's Avatar
Moderator
We have 2 the first is a loaded 6 speed 98 SS t-top at 3380 with 1/4 tank of gas.
And the other is my 00 Formula A4 hardtop, cloth at 3400 with 1/4 tank.
Old Jan 24, 2004 | 09:23 PM
mullettour's Avatar
Thanks alot guys. What could I get the weight down to by removing the spare tire, jack and rear seats. Also if there is anything else you remove to drop some weight I would appreciate the info.
Thanks,
Josh
Old Jan 25, 2004 | 08:52 AM
Rice Eater 316's Avatar
Mine weighed at 3440 with full tank of gas.
Old Jan 25, 2004 | 07:38 PM
StylezZ28's Avatar
3660 with like 2 gallons of gas. Of course i am a vert 2 Full interior car as well.
Old Jan 25, 2004 | 08:05 PM
DanBUCF's Avatar
Not sure how much my car weighs..my guess is that it would have to be pretty light to get down the track as quick as it does. How do you guys weigh 'em?
Old Jan 25, 2004 | 11:50 PM
mullettour's Avatar
Well you take a jack and a bathroom scale and. . .
Nah, they have a scale here on base so I weighed mine there, but lots of truck stops have scales you can use (sometimes they charge), landfills and recycling centers.
Check around and you can prolly find one close.
Old Jan 26, 2004 | 01:22 PM
Thanks,
Josh
jack and spare = 40-45 lbs. + rear seats = 20ish lbs.
front swaybar weighs 15 pounds and helps the front suspension unload on launch for better weight transfer.
skinnies and lightweight drag wheels are a HUGE help.
floormats are about 10 lbs altogether
lightweight battery saves about 25 lbs over stock (one of those 13 lb dry cell things)
A/C is a good thing to ! if you don't find yourself needing it very often...its a pain to take out but its a good amount of weight off the nose..
Aftermarket torque converter cuts about 15-20 lbs in addition to its obvious performance improvement.
my car weighed 3430 with me in it with only rear seats/passenger seat removed (one time track day thing lol), floormats and hatch well cover removed and jack and spare removed...(granted im only 140 lbs.)
Old Jan 26, 2004 | 01:32 PM
StylezZ28's Avatar
floormats 10 pounds? wtf? u got steel floor mats or something?
Old Jan 26, 2004 | 02:04 PM
psychocabbage's Avatar
3470 with full tank and me not in it.. .stripper with T-tops..
