!! Push Rod Madness !!
Old Jan 23, 2004 | 12:55 PM
CODY BEHNKE's Avatar
I told a bunch of people I know about this site and now every time they race or rod there LS1's they ask me about bent push rods.
Seriously if you bend a push rod you should be able to hear some noise 99% of the time right? I think all of the push rod posts are causing panic.
Old Jan 23, 2004 | 03:46 PM
Gold Z's Avatar
If you bend a pushrod you will be able to hear it 99% of the time is correct. It will be a tapping or clicking type of sound that will increase in intensity when the rpm is increased. Usually it takes a major over rev situation to bend a pushrod. An example would be trying to go from the top of 3rd gear into 4th and hitting 2nd instead. Cars with automatic transmissions generally don't have to worry about bending pushrods. Luckily pushrods are easy to change out and the hardened pushrods, which are much harder to bend, are fairly inexpensive.
Old Jan 23, 2004 | 07:26 PM
Am I correct in thinking it won't go away when warm right? Alot of people mistake loud GM valvetrain noises for lifter/rod problems but that usually decreases in volume when everything is warm.
Old Jan 24, 2004 | 01:14 AM
Gold Z's Avatar
The ticking will not go away period until the bent pushrods are replaced. Performance will suffer because bending a pushrod effectively shortens it's length which means the associated valve cannot open as far....less lift=less performance.
Old Jan 24, 2004 | 11:24 PM
00LukeyWS6's Avatar
Let's not forget the rough idle.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
