Battery Corrosion
Old Jan 14, 2004 | 01:27 PM
SSquared's Avatar
Battery Corrosion
What would cause major corrosion buildup on the positive battery terminal? Large chunks. I know how to clean it, but I want to find the root of the problem.
Electronically, my car is completely stock.
Old Jan 14, 2004 | 01:41 PM
mullettour's Avatar
This interested me so I did a little search on yahoo and this is the best answer I could find.
"Oxygen, moisture and pressure combine to form a perfect environment for growing corrosion on a conductor. Add an electrolyte such as salt water or leaking battery acid to the exposed copper and you have created a great fertilizer for the turquoise fur that eats wires from the inside out and causes some of the weirdest symptoms and hardest-to-trace electrical problems. " Here's the link to the web site I found it at if you want to read what else it says.http://www.asashop.org/autoinc/sept2002/techtotech.cfm
Old Jan 14, 2004 | 03:00 PM
98formyws6's Avatar
try using petroleum jelly (pretty sure its the same thing as vasoline) on the terminals to prevent build ups
Old Jan 15, 2004 | 07:32 AM
SSquared's Avatar
Thanks for the link to the article. It really makes me wonder about the safety and condition of wiring in older vehicles.
I wasn't aware of the petroleum jelly trick. I'm going to apply a generous coating.
Thanks again.
Old Jan 15, 2004 | 02:59 PM
watsonusa's Avatar
If you have an ACDelco side-post battery it may be leaking from the terminal. I've heard this is a common problem.
Old Jan 15, 2004 | 04:21 PM
NEWBIE T/A's Avatar
Thumbs down I'd say - BINGO !
IMHO, A/C Delco battries as installed as original equipment SUCK !!
The one in my '99 SS cratered - after warranty, of course, and messed up the positive terminal. It is still messed up as it apperas to be a major PITA to jack w/.
The one on my wife's '02 Saturn did the same.
Dealer got to play w/ that one, though - and I don't think it hurt the wires.
Another buddy lost the battery like that in his '01 Z71, and a guy at work in his '00 C1500.
Getting the picture ?
My .02 , anyway.
Britt
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
