Clunk noise when rolling over bumps
Old Jan 10, 2004 | 03:59 AM
RxNupe's Avatar
I'm now getting a clunk noise coming from the right front wheel area when i roll over bumps. It almost sounds as though a suspenion part has come apart. It sounds simliar to when my brake caliper came a loose on my LT1. I checked the brake caliper but it's in place. Anybody have any ideas?
Old Jan 10, 2004 | 06:22 PM
OutlawLS!'s Avatar
One of your front bushings on the front right side is bad.
Its worn out and everytime you go over a bump or brake pretty hard, the wheel will shift back and fourth slightly causing a clunking noise.
I had the exact same problem on my Tbird.
Most likely that is it.
Old Jan 11, 2004 | 12:12 AM
RxNupe's Avatar
would this be normal wear and tear or could this be a warranty issue seeing as though i only have 31k miles?
Old Jan 11, 2004 | 01:56 PM
CODY BEHNKE's Avatar
Whats the best way to check this stuff out? Mine also has a noise over bumps. On the dual a-arms are there just regular bushings? Most of the time it's the large disk bushing but mine appears to be fine.
Old Jan 11, 2004 | 02:47 PM
Dark Angel's Avatar
I have the same problem and would like to know how to check which one is bad.
Old Jan 23, 2004 | 02:51 PM
RxNupe's Avatar
my problem... bad strut on front right side. luckily i'm at 32,000 miles therefore GM picked up the tab.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
Aug 5, 2015 08:35 AM
