Help!!! Where is the Control board???
Old Jan 17, 2004 | 08:31 AM
wewa's Avatar
Question Help!!! Where is the Control board???
Hello
I have ordered a Powerchip for my Camaro 02 but I can’t find the Control board for the EPROM. Is here any Body who knows it?
Many thanks
Regards
WeWa
Old Jan 17, 2004 | 12:59 PM
chpmnsws6's Avatar
the ECU is on the far passenger side inside the engine bay. if you could see thru walls you could go to the passneger side where ppl put there feet, look up, and you would see it.
the data port is at your right leg on the drivers side about 10 inches from your steering wheel.
good luck and welcome to the board!
Old Jan 17, 2004 | 03:48 PM
Gold Z's Avatar
Your Camaro doesn't use a replaceable chip in it's computer. Instead it's computer is accessed through a port located below the dash just to the right of the steering column. All aftermarket tuning devices connect to that port and simply download programing to the computer. You would use the same devive that installed the "program" to change it's parameters or completely remove it. If you did actually order a chip then it will not work with your car.
Formula Steve
Sep 19, 2015 08:48 PM
z28cam1993
Sep 9, 2015 04:08 AM
Louey
Pacific
Sep 1, 2015 07:19 PM
TGGodfrey
Aug 17, 2015 08:43 PM
KYWes
Aug 10, 2015 07:03 PM
