Should I have had my flywheel balanced?
My car shakes bad above 90mph in 4th, 5th and 6th gears and in between shifting. At first I was thinking transmission or driveline/ rear end but i saw a post about a guys flywheel with similar problems. I had the flywheel in my sig installed straight out of the box with my Spec stage 2 because SPEC said it was "zero" balanced. Could this be the problem?
Re: Should I have had my flywheel balanced?
dude...how does you car shake?
im having a very similar problem, and i want to see if it may be the same reason.
http://web.camaross.com/forums/showthread.php?t=436252
check it out...and pm me if you can..
The LT1 rotating assembly requires an externally balanced flywheel. Your engine should be vibrating badly at all rpms if you have a neutrally balanced flywheel.
Formula Steve
Sep 19, 2023 08:31 AM
karpetcm
Sep 29, 2015 10:08 AM
