T-56 Tranny help Please
Old Mar 21, 2006 | 04:19 PM
tyrone_biggums's Avatar
Hello, I had a mainshaft problem in my t-56 transmission for my trans am and I was wondering if a 30spline mainshaft from a Viper would fit? Thanks in Advance for your help.
Old Mar 21, 2006 | 04:43 PM
97FormulaWS-6's Avatar
Re: T-56 Tranny help Please
AFAIK there is machining required, it's not a drop-in-replacement.
D&D wants $800 for the shaft, reluctor ring, and to maching the tailshaft housing to accept the new driveshaft seal and bushing, as well as the required viper yoke.
Old Mar 21, 2006 | 04:57 PM
Well, thanks, is that machine common in tranny shops or would I have to take it to a special place? I already got the shaft.
Old Mar 21, 2006 | 05:44 PM
I don't know what's required actually as for machining of the shaft and tail-housing.
And I doubt a tranny shop would have the Mill and Lathe required, more like an engine shop. The hard part is knowing what dimensions to machine the shaft and housing too.
I'm most likely going to by the shaft, ring, bearing, and seal from D&D, and see if they'll tell me what I need to machine for the tail-housing (I have access to a Mill where I can do this), and get a Billet Yoke from my drivetrain place (Denny's Driveshafts is local for me)
Old Mar 21, 2006 | 10:28 PM
crzhrs's Avatar
You do not have to machine the shaft. But you do have to cut a little off of it. Most any machine shop should be able to do the work on the tail shaft.
Good luck getting any of the parts needed from D&D. They want you to buy thier kit for $800.
G-BODYT56
Jan 14, 2022 11:14 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
