Stock Flywheel Vibration?
Old Mar 21, 2006 | 02:22 AM
Sweetred95ta's Avatar
I did an A4 to M6 swap and I have a vibration now. It vibrates pretty good at and above 2500-3000rpm. The only thing I can think of is the flywheel (stock). I bought it off of a buddy of mine who had just had it turned. Would the factory balancing not be right for a motor that has been internally balanced and blue printed? I didn't have any problems with my stock flexplate, but then again, the flywheel is much heavier. I really didn't want to pull the tranny back out, but I'll do what is necessary. What do you guys think?
Benji
Old Mar 29, 2006 | 04:20 PM
Re: Stock Flywheel Vibration?
Does anyone know anything about this? I need to find this vibration before I start driving the car again. I guess if no one knows anything, then I can pull the flywheel back off and have it zero-balanced. Has anyone else had this problem or know of something it may be? I appreciate it.
Benji
Old Apr 1, 2006 | 11:47 PM
StudyTime's Avatar
Benji
Benji,
Yes that flywheel is supposed to be zero balanced. Take it to a shop and have it and the PP balanced together. I actually pulled my transmission tonight to do this exact thing. My car had a vibration ~1400 from a ground down billet flywheel that wasn't rebalanced.
Ben T.
Old Apr 2, 2006 | 07:42 PM
I appreciate it. What does that usually cost? I will get started on that probably tomorrow.
Benji
Old Apr 2, 2006 | 10:06 PM
StudyTime's Avatar
Benji
Our local shop charges $65 for a zero balance for a flywheel and pressure plate.
Ben T.
Old Apr 3, 2006 | 06:00 PM
I started on mine. I will have it out this week sometime. I appreciate everything.
Benji
Old Apr 4, 2006 | 09:20 PM
OBE1 95Z28's Avatar
You stock flexplate was not neutrally balanced from the factory Usually 355's aren't internally balanced. Double check your flexplate and use that as a guide for your flywheel.
Old Apr 4, 2006 | 09:49 PM
The flexplate wasn't balanced from the factory. It was balanced with my rotating assembly. Why woudn't 355's usually be internally balanced? You can internally balance anything, if you want to pay for it. The flywheel is different than the flexplate though. I'm taking it to a machine shop to get it balanced. I have to wait until the guy balances a 1 piece rear seal crankshaft so I can get it done. All he has right now is 2 piece seal cranks.
Old Apr 5, 2006 | 09:46 AM
OBE1 95Z28's Avatar
"You can internally balance anything, if you want to pay for it."
True statement; that's why 355's aren't usually internally balanced. If your flexplate was used to balnced the 355 rotating assembly (as it should have been), then my statement above is still true: "Double check your flexplate and use that as a guide for your flywheel."
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
