Diff. Question Backlash
Old Mar 12, 2006 | 01:29 PM
1982's Avatar
Can anybody tell me is 6 thou backlash would be ok. auburn 7.5 pro series posi W/410 gears street/strip use, thanks len
Old Mar 12, 2006 | 01:47 PM
MyShibbyZ28's Avatar
Re: Diff. Question Backlash
I think it is suppose to be from .004 to .008 but I am not 100% certain. Someone else should be able to confirm/correct this.
Old Mar 13, 2006 | 12:47 AM
NovaTodd's Avatar
It depends on the gears you are using. Each company uses their own specs. Look at the instructions or manufacturer's website to see what they recommend.
Old Mar 16, 2006 | 11:26 AM
Capn Pete's Avatar
Richmond, for example, says aim for .008", +/- .004". So you can run from .004" to .012" and that's acceptable. They even say for oval track racing, run as loose as ~.020" I believe? (been a while since I read the specs). I think we set my 4.10's on the slightly looser side, but I still do quite a bit of highway driving with my car . They've been perfectly quiet though since day 1 .
Common knowledge / practice, and what's typically recommended by the manufacturers is that the less backlash, the better, for drag racing purposes (basically, so the gears are almost always in full contact, or really close to being in contact). Having an automatic, when I drag race, usually I'll have my feet on both pedals, and I'll pre-load the drivetrain before launching, so even with more backlash, the slack gets taken up.
But anyway, I think .006" is just fine .
Old Mar 16, 2006 | 06:44 PM
angel71rs's Avatar
It's ok, might actually make for a stronger install. Gears seperate a bit under power, but tighter usually means noisier.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
