Is this a torque converter problem?
Old Mar 15, 2006 | 01:14 PM
rlax31's Avatar
In my girl's car (not a f-body, but bear with me) when you press the gas from a stop often times it will stumble a little before it accelerates smoothly. I was thinking this is probably a torque converter problem, and I probably need to replace it. Could it be anything else?
Her car is a 99 taurus BTW
Old Mar 15, 2006 | 01:47 PM
IHI's Avatar
IHI
Re: Is this a torque converter problem?
More than likely a sensor under the hood, even though your not popping a check engine light you may have a faulty sensor somewheres. Either rent a scanner from an auto store or run it by a shop and pay them $30-40 to perform the scan and make sure it's not 1 of 100 sensors that are bad. FWIW my F-150 would pop a check engine light once every couple months for a second or 2 then go out, finally started ideling funny and found it was a bad throttle position sensor, replaced that, cleared codes and tried again, found 2 other things needing replaced after I fixed the inital problem LOL!! So imo it's worth scanning for piece of mind, too much crap on these new cars to point a finger on 1 thing since everything works together nowdays
Old Mar 16, 2006 | 09:29 PM
nikkev's Avatar
Maybe a bad plug wire?
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
