will a 94 4L60E work in my 96?
Old Mar 9, 2006 | 09:42 PM
baddboy1705's Avatar
just as the title says.... will a trans (4L60E) out of a 94 Z work in my 96 Z? also has a 4L60E Ive been told both yes and no ... please dont post unless your 100% positive!!! thanks
Old Mar 9, 2006 | 09:52 PM
Dave89IROC's Avatar
Re: will a 94 4L60E work in my 96?
no, in 95 they went to PWM(pulse width modulated) TCC(torque convertor clutch), so 95 and up are not interchangable with 94 down(there is also a change in the case design in 97 i think?)
Old Mar 9, 2006 | 09:57 PM
thats what IIIII thought....thanks!
Old Mar 10, 2006 | 08:46 PM
Ricardo's Avatar
I am actually running a built '94 4L60E in my '96.
It did work in my case, with the following adjustments:
1) Had to disable the TCC PWM solenoid hardware verification test (P1860) with LT1 edit.
2) Swapped transmission tailshaft housings. The speed sensor was slightly different and on the opposite side.
3) The TC cover has different screw hole positions. It can be modified or you can get another one.
I did the swap myself. I know it works.
I run a Vigilante 2800 RPM TC with it. It locks and unlocks just as programmed.
RG
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Brake_L8
Jan 20, 2015 09:44 AM
Snoman73
Nov 17, 2014 07:22 PM
