trans brake for 4L60E
Old Mar 5, 2006 | 06:05 PM
viper03af's Avatar
before you guys tell me to get a 4L80E IT DOES NOT BOLT UP TO THE V6 CAMARO's
Rossler will have trans brake out for the 4L60E soon and the 4L80E is out already. http://www.rosslertrans.com/4l80e.htm
Rossler biult my 4L60E, i want a trans brake becuase with the turbo i can't stall over 3000 RPM on the foot brake or the car rolls forward on me
www.rossler.com for more info.
I'm running 12.036 right now on 1.9 60 foots i realy only want to get the 60 foot down to 1.6's or so..
what do you think ?
Old Mar 5, 2006 | 11:11 PM
n20ta2's Avatar
Re: trans brake for 4L60E
A trans brake on a 4l60e is a bad idea adding more shock and stress to an already weak trans,not only that but its definetly a bad idea with a stock 7.5 if you still have that in there.How about a higher stall speed like a 4000?
Old Mar 5, 2006 | 11:30 PM
viper03af's Avatar
stalls are rated for trans brake stall not foot brake stall, from what i was told, so to get a stall i can foot brake to 3500 would probly be way to loose wouldn't it?
even a fully biult 4l60E can't take the trans brake?
also the rear is a eaton carrier with 3.42's and TA cover
Old Mar 6, 2006 | 05:51 AM
Pro Built Automatics's Avatar
If you have the Vig right now, then a torque converter change is only going to help a 1/10 in ET or a little more on the 60 foot times, unless the torque converter is mismatched to your current setup, which does happen. Trans-brakes do not improve 60 foot times in the majority of cases, just give more consistency for bracket racing, and are harder on the gear train.
Old Mar 6, 2006 | 07:25 AM
viper03af's Avatar
but wouldn't the trans brake let me stall higher? witch means i could lanch in boost?
i'm still learning about the auto stuff lol
james007moore
Jan 1, 2016 01:14 PM
Brake_L8
Jan 20, 2015 09:44 AM
funina91ss
Aug 6, 2002 11:20 PM
Redbird
Jul 31, 2002 08:20 PM
