3.73 Gears with Stock Rear End
Old Mar 10, 2006 | 10:15 AM
jasonwinn's Avatar
I am on my quest to figure out exactly what I want for my car
I would really like to get 3.73 gears in my 96z A4. Everything is stock atm (shortly will change )
My question is if I get 3.73 gears, will I run the risk of blowing my transmission or causing serious injury to my car, if I just have the stock back end?
I wont be taking this to the strip or launching (would like to launch but understand I need a beefier back end like a 12 bolt)
Jason
Old Mar 10, 2006 | 01:06 PM
00cls1camaross's Avatar
Re: 3.73 Gears with Stock Rear End
it really depends on the amount of hp on your car.... if you have a stock car or pretty much stock then you should be fine...as soon as your put a converter and stick tires on it then it will go snap! it may even go soon it is a real luck of the draw kind of thing... everything else is fine if you put 3.73 geras on there
Old Mar 10, 2006 | 01:22 PM
jasonwinn's Avatar
I am planning:
Roller Rockers
CAI (is on the way)
Headers
Nothing else at least for 3-6 months.
If i do decide to build the back in, its a few thousand correct?
Old Mar 10, 2006 | 04:11 PM
nb 96 z's Avatar
Yeah around 2 grand.
Old Mar 11, 2006 | 03:20 PM
Demon's Camaro's Avatar
You should be fine, A4's preload the rear end so there isnt as much shock to it as a M6 puts out. There have been a few stock rears in the 10's.
oldschool
Feb 9, 2016 09:21 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Cam's maro
Dec 28, 2014 09:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
