HELP! List your dyno #'s and 1/4 times.
Please list you DYNO NUMBERS and 1/4 times with what type of gear and tranny you are running.
IMPORTANT to this post.
*** if you are running a stall converter PLEASE LIST STALL SPEED AND LOCK UP OR NON-LOCK UP!
I have two cars.
2000 Camaro SS M6 310rwhp 317ft-lbs 13.5 at 104mph
1977 Vette LS1 w/comp cam .581/.581 220/235 auto 3000 non lock-up 10in converter 3.36 gears.
? ____rwhp ____ft-lbs ____@ ____mph?
THANKS GUYS!!!
I am testing and tuning my new LS1 vette and trying to get ideas. I understand that a non-lockup converter will hurt your dyno but help your 1/4 times.
I have two cars.
THANKS GUYS!!!
Re: HELP! List your dyno #'s and 1/4 times.
99z28 bolt ons, no headers, no pulley, or ls6 intake 120k miles
13.36@105.........a4 no dyno yet
curious to see other peoples reply's to get a ballpark of where I'm at
Bone Factory Stock 2002 Z28 with only 3 options (Leather Steeringwheel, Factory Hurst, and T-tops) 320rwhp/337rwtq 13.1@108
My factory sticker
My factory sticker
my Ls1 vette did 259rwhp and 337ft-lbs this is with a 3000 non-lock converter and 3.36 gears
Still have some tuning and minor things to change....
I need a bigger power valve...Ls1 is hungry for fuel. Change to MSD chip to stage 6..put on my larger spacer.
get smaller rear tires. I am running a huge 275/60R15
2000 Z28 "stripper" 6-spd 436/420 N/A 576/590 on a TNT 100shot
I have to put my clutch in before I hit the track...
I have heads/cam and most of the bolt-ons... I'm putting in my bigger injectors and gonna try the 150shot for laughs.
2002 Z28 M6 with bolt ons...
SLP lid and bellow, K&N filter, Free Ram Air, TB Bump Stop Mod, Taylor 10.4mm wires, NGK plugs, FLP headers w/ ory pipe, Borla Catback, 160* thermostat, tuned.
No recent dyno numbers yet after tune, 160* thermostat, NGK plugs, Taylor wires, Bump stop mod, and Free Ram Air.
Dynoed May 2003, 356rwhp - 354rwtq
417 RWHP @ 5200 , 445 RWTQ @ 4700
383 LT1 w' LT4 heads/intake, headers, Twin-Intercooled ATI Procharger (8#), CC-304 "baby cam", 6-speed, 3.73:1,
With a horrible 2.224 60', I only pulled a 13.107 @ 110.87
If I only had drag radials and ACTUALLY knew how to launch an M6, it might actually break the 12s.
Um, let's see.
Best ET 12.30 @ 117
360 rwhp (I still don't believe that)
4.10 gears
Stock tranny w/ trans cooler and shift kit
2800 stall lockup converter
Drag radials
Note: I can't drive. My friend ran a 12.12 in MY car.
Best ET 12.30 @ 117
4.10 gears
Drag radials
Originally Posted by GPZ28
You cant get into to 12's with 417 rwhp? Thats enough for 11's
