How do you disable VATS? (Passkey)
Old Aug 29, 2005 | 04:20 PM
ZekesZ's Avatar
I own a 1999 Z28 (M6) and recently it started giving me some problems starting. I would have to try to turn the key several times before I would get the thing to crank. After it started the security light would stay on for awhile then eventually turn off. Last weekend the thing wouldn't start for anything so I wound up poping the clutch and driving home with the security light flashing the whole time. So I have 2 questions,
1.) I don't want this system in my car any longer, it's usless (as evidenced by poping the clutch and driving off) and only serves as an inconvinence. I've heard of people just putting a resitor in line with a couple of wires heading to the ignition, would this solve my problem?
2.) Does anyone have any specific details on how to do it? I know it involves finding the resistance of you pellet and so on an so fourth, but has anyone put together a decent site or technique for disabling it?
Any help that you could give would be greatly appreciated. Thanks in advance,
Karl
Old Aug 30, 2005 | 11:42 AM
SublimeZ's Avatar
Re: How do you disable VATS? (Passkey)
You'll need a GM parts dealer to "read" the key and give you the ohms range. Get the appropriate resistors from Radio Shack. At the bottom of the column there is a 2 wire connector with small(22ga.?) wires. I think mine were orange(98 Z/28). Use correct resistance to bypass the ignition. Hope this helps.
Old Aug 30, 2005 | 02:59 PM
ZekesZ's Avatar
Cool thanks, I've heard orange before also but I wasn't sure, thanks again
Old Aug 31, 2005 | 12:21 PM
foff667's Avatar
it can also be tuned out
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Aug 7, 2015 08:52 AM
