Which one is unbearable
Old Aug 22, 2005 | 12:05 PM
lil305gta's Avatar
Which one resonates more and flows better the LMII or the Hooker exhaust?
Old Aug 22, 2005 | 01:25 PM
Greed4Speed's Avatar
Re: Which one is unbearable
LM will be much louder.
I doubt there is much difference as far as dyno #'s between the 2.
Old Aug 22, 2005 | 01:51 PM
unvc92camarors's Avatar
The LMII will flow more and be louder. The Hooker only suffers from the crossflow design, which isn't the greatest, but helps make the car look good
The LM and LMII are basically glorified cutouts. My buddy has one though (LM on an LT1) and it's pretty cool.
The other thing to consider is that the LM and II are stainless steel and Hooker is aluminum. The aluminum will rust eventually (pretty quick up here in the midwest) but I have no idea what the weather is like in your part of the Netherlands.
Old Aug 22, 2005 | 02:06 PM
lil305gta's Avatar
How does the loudmouth II sound in comparison to the flowmaster set-up.
Old Aug 22, 2005 | 03:48 PM
SFB767's Avatar
www.ls1sounds.com
Old Aug 22, 2005 | 07:39 PM
W/headers and no cats every LM I've heard sounded like a truck w/glasspacks.
Old Aug 23, 2005 | 08:19 AM
TheMT1's Avatar
Um, do you understand how aluminum oxide works or did you not mean to type aluminum? All aluminum rusts. The rusting process is what makes it strong. It essentially becomes a sapphire chemically. The only thing really much stronger is diamond. So I don't know what the weather is like where you live, but unless it's raining mercury (which wouldn't be too good for your health) I don't think the aluminum will fall apart.
Old Aug 23, 2005 | 09:50 AM
Actually stainless will rust too, and SLP doesn't use the best grade.
Zfbod94
Jun 27, 2013 10:16 AM
raroz28
Mar 11, 2012 07:00 PM
