Header Install guide?
Old Sep 7, 2005 | 09:41 AM
black02z28's Avatar
How difficult is it to install LT headers on a 02 Z are there any sites for step by step instuctions and also can I reinstall my stock cats?
Old Sep 7, 2005 | 09:49 AM
SSpdDmon's Avatar
Re: Header Install guide?
Check teke's site. http://www.cardomain.com/ride/243722/11
Old Sep 7, 2005 | 09:51 AM
teke184's Avatar
as i posted in the other thread
link
the install is pretty easy, just time consuming. 10hrs, by myself from start to start up.
i listed some tricks on my site to help out.
as for the cats, not sure you'd want to. even if you did you would need to have them custom welded up. not to mention most LTs are 3" collectors, and stock cats are 2.5" i think. you'd be better off buying hi-flow cats with 3" tubing.
Old Sep 7, 2005 | 09:57 AM
black02z28's Avatar
Can I use ramps to drive up on or is it not high enough,and also what are good high flow cats,but I may go with TSP True Duals instead would cats hook up to those?
Old Sep 7, 2005 | 10:49 AM
teke184's Avatar
damn SS you beat me to it while i was typing
ramps may be high enough...but i doubt it. it REALLY needs to be high
like i said stock cats are smaller than the collector on the headers. yes they could be re-used, but a custom fabricated Ypipe or set of true duals would need to be used.
TSP true duals are 3" pipes, so to use stock cats you'd be restricting the pipe down to 2.5" before entering the duals...not very efficient.
check ebay for cats, i think magnaflow makes some good inexpensive ones. why are you worried about cats? emissions?
if at all possible...get rid of them
just looked up cats in my Jegs catalog. magnaflow has some for $110 and dynatech has some for $150
Old Sep 7, 2005 | 11:01 AM
black02z28's Avatar
Yes here in massachusetts they are very strict so I'm looking for the best LTs and true dual setup and highest flowing cats so your saying the aftermarket cats will fit on the tsp dual setup,and also I won't throw any codes by putting LTs in right?
Old Sep 7, 2005 | 11:15 AM
teke184's Avatar
if everything is done properly, and everything is hooked up right...you shouldn't throw codes.
although altering the car's design affords you no guarantees.
not sure where the cats would fit best on the TSP duals. you'd have to ask them. i know right behind the driverside collector on my Flowtech LTs there is some frame clearance issues, so i don't think you could fit the cats immediately off the collector. but splicing them in the true duals slightly farther back shouldn't be a problem. i would call or PM trevor at TSP and see what he says.
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
alphaauto
Jan 23, 2015 07:42 AM
LT4Ryan
Jul 29, 2002 08:38 PM
