Firing order
Old Aug 3, 2005 | 12:49 AM
ChicagoTransAm's Avatar
Firing order
After my header install...ran into some problems
1) Bank 2 Sensor 1 - O2 sensor no signal
2) Cylinder 5 misfire
Also noticed that I have 7 TR55 and one TR6 ....hmm... Bad feeling this car was sprayed?
Back to the question at hand...which cylinder am I looking at for my misfire? Plan on doing wires/plugs tomorrow but want to confirm the problem first....thanks!
Old Aug 3, 2005 | 12:50 AM
Re: Firing order
Oh...and forgot to mention, that Ion tuned out my O2s ...so it "should" be only getting a code on the fronts (if it is in fact faulty)
Old Aug 3, 2005 | 01:16 AM
sssalah's Avatar
Re: Firing order
Sensor 1 is the front sensor and bank 2 refers to the passenger side bank, check the wires & connection.
The firing order on GEN III is 1-8-7-2-6-5-4-3. The #5 cylinder is the third one on the driver side bank.
Old Aug 3, 2005 | 03:36 AM
Re: Firing order
Checked the wiring...is this possible? That the O2 went not 20 minutes after firing it up with new headers? Ehrr? Or could it be bad extensions? Used the ones that came with my headers.
I have heard the coating can kill O2s...but that quickly? I had a "lean" code on bank 2 as well...could this be the last code it tossed before failing completly?
Old Oct 10, 2005 | 09:58 PM
derek83z28's Avatar
Re: Firing order
whats the firing order for a 88 camaro v6 2.8l
Old Oct 11, 2005 | 04:49 AM
Re: Firing order
I hope you're kidding You are asking about a 2.8L in an LS motor forum?
KYWes
Jun 14, 2022 06:52 AM
RUNMYTA
Jul 15, 2015 07:50 PM
Strick
Jul 14, 2015 07:28 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
surreybrad
Jul 5, 2015 10:36 PM
