Pics of my Loudmouth installed
Old Aug 20, 2005 | 02:08 PM
94zLT1's Avatar
Heres a few pics of my Loudmouth installed. went with the 3.5" slash tips. wow does it sound good and mean. it looks exactly how i wanted. this type of exhaust/tip combo on a ta, IMO, cant be beaten. :hail: :chug:
http://i14.photobucket.com/albums/a3...8/P1010442.jpg
http://i14.photobucket.com/albums/a3...8/P1010439.jpg
http://i14.photobucket.com/albums/a3...8/P1010440.jpg
http://i14.photobucket.com/albums/a3...8/P1010443.jpg
Old Aug 20, 2005 | 02:13 PM
Derek_91's Avatar
Re: Pics of my Loudmouth installed
looks good except for the clamps that hold the tips on.
Old Aug 20, 2005 | 02:18 PM
00Z28SS's Avatar
He can reposition those so the bolts aren't showing, or even cut the end of the bolts like I did. Looks good.
Old Aug 20, 2005 | 02:20 PM
marcus769's Avatar
I have the same setup on my 96, and i would definately recomend getting it welded on. Mine kept shifting around. Sounds real good that is for sure.
Old Aug 20, 2005 | 05:03 PM
SFB767's Avatar
It looks like a nice, clean install.
I agree with the others about the clamps, try and take them off and weld those areas, it'll make the system look even better.
Did you get the SLP y-pipe too?
Old Aug 21, 2005 | 10:15 AM
lil305gta's Avatar
A few folks told me you have to drop the rear end to get the exhaust on/off, how true is this?
Old Aug 21, 2005 | 10:24 AM
SFB767's Avatar
That's not true.
There's enough room to get it over the axle without lowering it.
Old Aug 21, 2005 | 11:43 AM
mark896's Avatar
Yea, the hardest part about the entire install was sawing the stock pipe off. Everything else was simple. I think it took 2 hours for the install.
Old Aug 21, 2005 | 04:01 PM
94zLT1's Avatar
easy install..only prob i had was getting the bolt off the i pipe to ypipe and pulling th stock i pipe out of the stock y pipe..also make sure you push down the over axle pipe to i pipe real clse and clamp REAL tight so it dosent come loose. i had mine welded. ya i will prolly have the tips welded and take off the clamps. i dont like the way u can c the 3" pipe in the 3.5" tips if you are looking low straight in so i may have them cut and weld accordingly
HectorM52
Jun 23, 2016 08:42 PM
Brake_L8
Jan 20, 2015 09:44 AM
Queens94z28
Dec 20, 2014 09:11 PM
Gotbass
Aug 2, 2002 11:42 PM
