Probably a Dumb question... ls1 vs lsX
Old Sep 14, 2005 | 01:12 AM
Toko's Avatar
I noticed that al ls6 had a little more hose power than a ls1. How much more? and is it worth it to fork out all that cash for one, or soup up an ls1?
http://cgi.ebay.com/ebaymotors/NEW-2...99047422QQrdZ1
How big of an engine can you put into a 1988 Iroc-z camaro? Is it good? I might just buy the weaker 305 iroc since I plan to do an engine swap anyway, as finding a 5.7 liter is proving to be very hard. What would it cost me to get like an ls7 or ls6? Or is 383 Stroker better? I don't want to cut corners in this depatment of the car...
Old Sep 14, 2005 | 06:34 PM
Kataklysm's Avatar
Re: Probably a Dumb question... ls1 vs lsX
I'd take the LSx over a 383 anyday. The reliability would be so much higher and the potential is huge for small bolt on parts. In a 3rd gen car you can put a big block in if you want so don't worry about what will fit and what won't. The LS6 isn't really worth the extra money comapred to the LS1, add a cam to an LS1 and you make the same if not more power then the LS6 but you save something like $2,000.
Old Sep 14, 2005 | 10:16 PM
Strahley's Avatar
Not to bash teh LS6, but it is cheaper and smarter to build up an LS1 over an LS6. I chuckle when I hear people wasting thouands of dollars swapping an LS6 into their LS1 F-Body, where all they needed was a cam swap to make more power from the beginning
Old Sep 15, 2005 | 10:32 AM
DrewSG's Avatar
Unless you are getting a great deal on the LS6 parts, I'd stay away from it. More power can be had for less money with aftermarket cams/heads
Old Sep 18, 2005 | 05:41 PM
Kataklysm's Avatar
This is true but some people look at it like this, the car retains totally stock feeling driveability and idle while making more power.
Old Sep 18, 2005 | 09:43 PM
Steve0's Avatar
You do realize that a Gen 3/4 small block isnt going to just drop into your 3rd gen dont you?
With that said, if you're on a budget you may be better off building a 1st or 2nd gen (LT1/LT4) small block into your ride.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
pepon214tx
Sep 20, 2015 04:48 PM
Z Power
Sep 19, 2015 11:19 PM
