Isn't the LS6 a bigger block than the LS1?
Old Aug 25, 2005 | 07:20 PM
Need4Camaro's Avatar
Whats the specs on the LS6? Isn't it like a 400 CI Block or am I thinking of another engine?
Old Aug 25, 2005 | 07:22 PM
6speedZ28's Avatar
Re: Isn't the LS6 a bigger block than the LS1?
Same size as an LS1
TheV6Bird's Avatar
Nope, LS6 is the same as an LS1, except the LS6 has better oiling passages.
Old Aug 25, 2005 | 07:25 PM
Silver's Avatar
the ls2 is a 6.0 for the vette and i believe gto...?
Okay... whats in the C6?
Old Aug 25, 2005 | 07:38 PM
Silver's Avatar
i believe the C6 has the LS2 standard right? and the LS6 is still in design phase? i ain't real sure bubba.
Old Aug 25, 2005 | 07:41 PM
6speedZ28's Avatar
LS6 was in the C5 Z06's and is WAY past the design phase.
Old Aug 25, 2005 | 07:42 PM
TrackMagicWS6's Avatar
C5-ls1
C5 Z06-ls6
C6-ls2
C6 Z06-ls7
Old Aug 25, 2005 | 11:32 PM
stangitr's Avatar
it's a supercharged dual rotor 502
Old Aug 25, 2005 | 11:43 PM
Bow94z's Avatar
the only thing different on the LS6 is the heads/cam and intake
Old Aug 25, 2005 | 11:53 PM
Strahley's Avatar
The LS6 454 was bigger, yeah
But the Gen III LS6 is the same size as the LS1, both 5.7 liters. The LS2 is a 6 liter, the LS7 will be a 7 liter
Old Aug 26, 2005 | 01:14 PM
Okay....
Old Aug 26, 2005 | 01:22 PM
Kraest's Avatar
Retired
Old Aug 26, 2005 | 02:23 PM
Bayer-Z28's Avatar
The LS6 block has thicker sidewalls. You can't get the over 4"-ish bore w/ an ls1. The LS2 block is the "purfect square" bore/stroke. like 4.02/4.00.... Pretty darn close.
Old Aug 26, 2005 | 02:59 PM
ChicagoTransAm's Avatar
I say GM should stop talking liters. I don't live in Europe da*mit. When having conversations with "the older crowd"...alot of times they'll ask what it is in my car. I'll tell em it's a 5.7 which equates out to a 350...So when I tell em it's a 347..they get on my case. Too much rounding off numbers and such.
