LS1 problem areas?
Old Jul 27, 2005 | 09:37 AM
JakeRobb's Avatar
Super Moderator
LS1 problem areas?
I'm considering buying a 2000 Z28 6-speed from a private seller. It has 70,000 miles on it and was driven year-round.
When I get to this guy's house and look over the car, are there any engine-related things I need to check out? For instance, if it were an LT1 car, I'd check the condition of the optispark. (LS1 doesn't use optispark, does it?). That's the sort of info I'm looking for.
Thanks guys!
-Jake
Old Jul 27, 2005 | 10:07 AM
Bert02SS
Guest
Posts: n/a
Re: LS1 problem areas?
My '02 SS needed a new waterpump with only 33K miles (under warranty, the dealer may have been padding, though). Check for seepage or leaks, it's right up front up high on the block face. The danged pulleys and/or tensioner make all kinds of noise, but I'm living with it.
Mine doesn't have this piston slap that is often mentioned on this board, but maybe your prospect does. Check that out.
It's a stout motor.
Old Jul 27, 2005 | 07:15 PM
GPZ28's Avatar
mine has 120k and the only problem I've had is a belt tensioner
great motor/car
Old Jul 27, 2005 | 07:16 PM
Greed4Speed's Avatar
Stock pushrods and springs, AC compressor, and the idler pulley likes to make noise.
Now f-body related weaknesses
Rotors, window motors, and rear end
Old Jul 27, 2005 | 10:49 PM
LT-14me's Avatar
The LS1 is basically fool proof. Some complain of piston slap others never have it. My car has 80k on the dot and i have never had pistion slap. Other then the mods on my car the only thing i have had to replace is thermostat, and the alternator
Old Jul 27, 2005 | 10:58 PM
Johnny Ray's Avatar
Freebird
64,000 on our '98 LS1 and th eonly thing I have changed are the sparkplugs and wires.
skittlez87
Dec 29, 2014 03:24 PM
squarehead
Nov 21, 2014 08:02 PM
guionM
14
Jun 19, 2002 08:30 AM
