where is the main sensor fuse? (other probs. as well)
My car just had a stroker motor swap. It didnt idle w/o putting your foot on the gas. But it ran fine for the first few miles, then started sputtering, shakeing, and cutting off. It would come and go, then finially got so bad it got to the point where it does consistantly now and cant even go above idle speed now.
I found a post where a guy had similiar problems and he blew the main sensor fuse. Where is the MAIN SENSOR FUSE located so i can check it out??????
Ok, now my car is only throwing a bank 2 02 sensor code. I found my front 02 extension wires fell ontop of my header but dont appear to be burnt through. They were wrapped in tape and it didnt burn through the tape asfar as I can tell at a glance but may be. But that dosent mean the heat didnt short it out. Im putting an actual exhaust on the header tuesday and new 02 sensors, as well as check out the main sensor fuse and hopefully fix the problem...
Feel free to throw in your advice but let me know where the main sensor fuse is!!!!
carguyshu
Jan 22, 2017 11:19 AM
