rocker arms?
Re: rocker arms?
do you know why its a roller fulcrum and not tip? just seems kinda odd to me. also do you know how they are mounted? i kinda wonder if anyone has used them on a gen 1 or 2 head???
Re: rocker arms?
stock rockers are fine. they say about .630 lift is max though. but alot of different things come into play. they won't work on any other chevy head.
i have patriot golds and 611/619 lift spin to 6800 stock rockers and lifters no problems yet.
matt
matt
Re: rocker arms?
because the roller tip is a myth of it working. if you've ever put a timing light onto a rocker while the engine is running, you'll notice the wheel doesn't move at all. but, the idea has been around for so long, it has stayed. crane cams is currently looking into making a roller pad instead of wheel.
autoxr166
Sep 25, 2015 04:21 PM
