weird noise
Old Sep 20, 2005 | 12:30 PM
Usefulidiot's Avatar
weird noise
got a question maybe some of you can help out
i have a 98 Trans Am and when i first start the engine it makes kind of a high pitched humming like noise sometimes it does it, sometimes it doesnt, but it goes away within 15-20 seconds never did it before and its kind of concerning, any ideas to what it might be?
Old Sep 20, 2005 | 08:11 PM
99_Z_155's Avatar
Re: weird noise
Yup, most likely the electric fans. Mine kicks on for a split sec, then comes off too.
Old Sep 21, 2005 | 08:44 PM
angel71rs's Avatar
Re: weird noise
The air pump comes on at startup, if it has a bearing going bad or something might be the source of your noise. You could pull it's fuse and see if noise goes away, but don't know if that would set off SES.
Old Sep 22, 2005 | 08:13 AM
teke184's Avatar
Re: weird noise
sounds like the air pump to me as well. should be inside the fender well behind the driver side headlight.
either pull the fuse to see if it stops or have someone start the car and listen for it.
Nayr
Mar 3, 2023 08:34 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
