oil drain bolt
Old Jul 30, 2005 | 09:50 AM
Green98's Avatar
oil drain bolt
trying to change my oil today however my oil drain bolt will not budge at all, anyone have any tips on how to get it out.thanks
Old Jul 30, 2005 | 09:56 AM
Keliente@pcmforless's Avatar
Re: oil drain bolt
Piggyback two wrenches so you have more leverage, or get a socket & a breaker bar.
Old Jul 30, 2005 | 06:03 PM
99blackSS's Avatar
Re: oil drain bolt
I use the handle from my floor jack as a pry bar. Don't put it on so tight next time, might strip it.
Old Jul 30, 2005 | 07:05 PM
Green98's Avatar
Re: oil drain bolt
thanks, yeah had to use another wrench to pry it loose. first time changing it in this car i geuss the previous owner didnt know how much was too tight.
Old Jul 30, 2005 | 07:43 PM
jfischer's Avatar
Re: oil drain bolt
20 ft/lbs is about what a drain plug in an aluminum pan requires. Sounds like somebody used about 120 ft/lbs!
Old Jul 31, 2005 | 12:35 PM
Bayer-Z28's Avatar
Re: oil drain bolt
A pipe wrench and a new plug...
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
