How much of a difference.....
Old Aug 22, 2005 | 03:02 AM
lil305gta's Avatar
Will it make if I swap in 3.73 from my 3.23 rear end?
Old Aug 22, 2005 | 03:13 AM
Strahley's Avatar
Re: How much of a difference.....
Gas mileage and traction might decrease. Acceleration and RPMs at cruising speeds will increase a bit. I would say you would feel a noticable difference from 3.23s to 3.73s. If you're an automatic (I assume you are given the 3.23s) I would reccomend that exact gear
Old Aug 22, 2005 | 11:56 AM
Greed4Speed's Avatar
A converter will do much more for you.
Old Aug 22, 2005 | 12:07 PM
lil305gta's Avatar
What converter do you recommend?
Old Aug 22, 2005 | 03:58 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile Re: How much of a difference.....
There is a >500 RPM difference between 3.23's and 3.73's.
SteveC
Old Aug 23, 2005 | 04:42 AM
Strahley's Avatar
I have a 4000 in mine, it's easily streetable. Let the brake off at a stop light and the car pulls away on it's own. Just don't floor it from a dig or a slow roll without at least a good drag radial
Old Aug 24, 2005 | 02:29 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
4000 is extreme...
if this car is your daily driver, i suggest going no higher than 3500 (vig 3200's seem to be a favorite) you are also prob gonna need mickey thompson radials (avoid nittos) or et streets or slicks to get the FULL potential out of a stall.
cleangene
Jul 19, 2006 10:00 PM
