Starting problem!?!?
Old Jul 26, 2005 | 08:21 PM
nitrobee's Avatar
I need some help. My car is a 99 SS Camaro, with zero mods and about 50,000 miles. Ever so often I try to start my car and it does nothing but crank over and over and over. Doesnt even try to fire. It seems to happen most often when it is hot, but not always. I get under the hood and jiggle wires around, unplug the coil packs and plug 'em back in and eventually it will fire. The thing is once its running it drives just fine and like it always has. No service engine light or anything. I wanted to know if anyone else has had a problem like this or has any ideas or tips as to what it could be. Any help would be appreciated. HELP! Thanks.
Old Jul 27, 2005 | 10:17 AM
JakeRobb's Avatar
Super Moderator
Re: Starting problem!?!?
Try this:
1. Make sure car is off and it's quiet around you.
2. Turn key to ON (NOT START).
3. Listen for fuel pump. It's a noticeable hum that should last for about five seconds, and it should come from behind you.
4. If you don't hear it, climb under the car and check the connection to the pump for power. Unplug the connector and look for corrosion. If there is power and no corrosion, you probably need a new fuel pump. If there is corrosion, clean it off thoroughly -- this should help your problem.
5. If you do hear the noise, then it's something else entirely.
-Jake
Old Jul 27, 2005 | 01:49 PM
Cincymaro88's Avatar
My 01 SS is doing the EXACT same thing. Let me know if u figure it out
Old Jul 27, 2005 | 02:02 PM
nitrobee's Avatar
Unhappy Re: Starting problem!?!?
I did the unthinkable and gave it to the dealer to look at. When they find out what it is and tell me what was wrong I'll let you know. It was not a fuel issue, the pump ran and I had pressure at the fuel rails, but thank you for the reply. Never thought I'd take her to the dealer but I could not figure it out and it just seemed to get worse.
Old Jul 27, 2005 | 03:26 PM
Bert02SS
Guest
Posts: n/a
You have my sincerest condolences on having to go a dealer. There's gotta be some competent repair shops in the Houston area.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
