View Full Version : LS1 Based Engine Tech
- Stupid Question? Heads and cam or Headers first?
- what the he11 is this?
- How many of you tune with AutoTap and a Translator?
- $1200 what mods?
- Stock LS1 1/4 mile times
- Just bought a mint* 98 Z28 w/M6......
- 18" wheels and lowering springs
- Shipping an LS1
- Installed Your Own A/F Ratio Gauge? Come in!
- Most Cost-Efficient Way to Achieve 450RWHP
- Sittin on the highway watching the temp gague go up...and what happens?
- dynomouth question
- Low coolant
- First time at the track.
- S.e.s.???
- Firehawk air lid on 01 WS6?
- Owners of Firestone Firehawk's
- Dynomouth
- HAL Shock & Springs Question
- Planning out my future LS1
- do perimeter and centerbolt use the same coils??
- What are some good adjustable shocks
- Which LS1?
- Replacing Dual Dual tips?
- 67 camaro or 98 camaro. help
- 15's for drag tires?
- does anyone know any auto part stores that carries these fog light bulbs?
- Advice please on wheel rubbing
- Shorties, Mid lenghts, or Long Tubes
- High-Flow Grilles??
- On the subject of stroking....
- Need carfax please
- spec stage II
- Switching a LT1 to a LS1or 6 in a 93-97 F-body?
- spark plug wires??
- Stroke it or Supercharge it
- First Dyno run with the Hawk
- Eaton posi in a 2001 Z28?
- Where To Get Lou Shifter????
- will my gears\posi fit in a 98 camaro.
- Nitto555R
- Need material to link Lid to MAF
- LS1vsLT1
- Dyno Run Results...Detonation Confirmed
- 97 ram air intake
- buying new tranny, please read here...
- T56 rebuild
- Aluminum driveshaft questions
- High stall torque converter
- What's a good bolt-on?
- 2000 camaro RPO #'s
- ASAP: BM Ripper question...
- Getting a FREE Flowmaster, questions...
- Header Nightmare!
- Did I make a good move?
- which pulley
- breakes and shakes
- Poll: Nitto Tires w/4:10 Gears
- Loudmouth Sound clips anyone?
- gauge overlays
- SSRA vs Downpour
- Clutch Help!
- 98Z28 Fuel pump started whining last nite???
- Jack Stand placement
- Dmh Electric Cutout Or Mpp2
- Dynomouth or Loudmouth?
- Ported TB results
- Viper T56 on an LS1?
- Shifter Solenoid ?'s...
- TTS Headers
- 315 on 01 ss
- knock
- question about airbox...
- Rear wheel width on my '02 WS6?
- tranny/clutch problems
- Shifter question.
- CLutch/tranny problem....??
- tranny/warranty problems
- Stall specs?
- bellows...form or function?
- Z06 Clutch/PP in 01 SS M6??
- Cutout questions
- hp loss keeping stock Ipipe?
- How to fix gauges????HELP
- 2 power steering pumps gone in 2 Weeks
- steering wander/drift
- Mobil 1 gear lubricant
- Problems after header install
- heads/cam time, friend needs advice
- New idea in header bolts
- New Source for Built Transmissions
- Vette MAF quest
- Suspension clunk in rear...due to mods?
- Torque Converter ?
- HP gains from headers
- What are the symptoms of a bad water pump?
- zo6 maf...compatability
- emissions hookups on headers?
- How many of you can make it 5K on an oil change before the light comes on ?
- did your mods void your warranty
- Head liner Price
- which short throw shifter
- On my way to true duals
- Anyone know the bolt size for the M6 shifter bolts?
- Muffler replacement and no more check engine light?
- What will an engine rebuild cost?
- A little smoke at startup
- Need Help Asap!!!
- Good Cam install shop around missouri or kansas.
- SLP Blemish Lid
- Transgo shift kit ... good idea or bad?
- Old man cam or LS6 cam??
- What type of spark plugs........
- what's wrong?
- Pacesetter vs Mac
- first time at the track this weekend
- low end gains?
- What bulbs for orange display backlighting on stock 'Bird stereo?
- New Brake rotors and pads Loud squeal
- 485 hp???????
- Laptop Mount?
- Best exhaust
- Tom Henry Camaro 1/4 times?
- 98 ta, turn headlights on, they come up, but then put to parking lamps and...
- Is it a 346 or a 347?
- Curious on LS1 1/4 Mile Stock times
- Brake Rotors
- car won't start because of security system!!
- carsound cats
- Weird bump stop
- 315 tire fitment
- Eibach Drag Launch Springs?
- Life after a gear, headers/exhaust....and why the SES light is on...
- Whine at 60mph to 65mph
- I'm buying a 11 sec Z28 next week..
- Exhaust Manifold
- thanks guys for your help!!!heres my setup
- Having a bitch of a time removing the oil pan...
- Pro's and Con's of a Billit flywheel for an A4...
- fastest top speed?
- Is 375 rwhp possible with a ZO6 cam and bolt on's?
- Help with A/f
- Got new tires!!!
- NEW 4th Gen Body Kit
- installing TSP lid, need new k&n gasket?
- Dropping a cylinder?????
- OEM SLP lid
- Here's what I ordered for my Ws6 today...
- K&N FIPK or High Flow Lid on an LS1?
- SLP long tube/ tuned headers?
- water pump?
- Is Cutout California Legal?
- 6 speed or auto
- Does an LS1 Camaro SS make use of a lid?
- Coolant Level Light
- new member pics of my ss
- NGK Spark Plugs
- B&M Ripper and short stick?
- 99 A4 dyno numbers?
- Coolant question?
- Grinding Reverse???
- Spohn torque arm, how are they compared to everyone?
- Hooker ORY Pipe
- Easiest way to run low 12's
- why does my car want to DIE??
- dual snorkle intake on 98 z28???
- CARFAX access people.....
- What will it be worth next summer?
- Prowd owner of a 2000 SS
- diablo question
- LS1 cross Drilled rotors that Dont warp
- warping brake rotors
- SLP Y-pipe Question
- How do I get the caliper floater pins out???
- Header question
- anyone know the weight of the hatch for a camaro
- nittos
- Performance differences: SS, WS6, Z28, TA
- After market lids.
- long tubes and double diamond sfc's
- How many ft/lbs. do I torque these?
- SS exhaust vs. Z28 exhaust
- Punching from a high speed roll
- Sub Frame Connectors
- What inexpensive options do I have for a torque arm?
- whats the biggest size tire that will fit the stock LS1 16x8 camaro rim?
- Header question
- Cheepest place for Hooker Catback system?
- will a 99 Hypertech programmer work for a 2000 model
- LS1 Block Costs?
- Steering Wheel Control Issues
- Finally got some pics of my new WS6
- BMR Sub-frame Connectors Help
- car is slow-help
- 4.10 Gears
- LS1 Tuning
- Know it all mechanic
- tsp lid or package deal
- noise after welding in the frame ties...what is it???
- How does this mod list sound? And a few questions...
- Lights on Steering wheel(radio controls) went out
- Exhaust Tips
- Got an extran 2 bills, Im thinking........
- Drag Tires for 16x8 rims?
- Eibach prokit Drag springs
- O2 Problems
- TA vs 03 Cobra (vid inside)
- Videos of your car
- Spectacle solutions
- hard to shift at stop.. '99 w/ 6-speed M6
- Pro-Kit Springs the same for '93-97 as '98-02?
- Got SES Code w/ these Mods
- Post your STOCK dyno sheets..
- pictures of BORLA tips
- Does my '01 WS6 have the LS6 intake?
- Best place to get drag wheels/tires
- Who has replaced A/C Compressor?
- ASCD, SCC, or other hood???
- Auburn differential
- Clutch Adjustment Help
- Dynomouth???
- are they needed
- Injector size of 99's vs's other LS1 F-body's
- Anyone here got a fast car with 2.73 gears?
- Engine Sluggish when starting
- 2001 Camaro SS RPO Codes
- Gauge Gurus Inside!
- I need help with HEADERS!
- MAF can water damage it?
- 2.73's to 3.42's Question!
- Best Longtubes
- anyone with a MAC torque arm had problems with the bolts grinding into the driveshaft
- torque arm/pinion angle
- timing chain
- Power steering and Tranny Fluid problems
- Lowering Springs
- Does a certain year have more power?
- Letting it breath???
- before and after dyno #'s
- hooker lts with slp y pipe
- Heads & Cam Installed!
- LS1 engine Swap
- Electric Cutout Switch.....does Fog Lihgt Switch Work?
- Different oil for racing all day?
- Wheel hop w/ 4.11
- How much is an '01 WS6 Trans Am worth?
- New Pulley
- This is Crazy
- Quick, I need mechanical differences between the LT1 and LS1
- Aftermarket oil pan...
