Wheel hop w/ 4.11
Wheel hop w/ 4.11
I'm getting wheel hop like a **** on the 1st to 2nd shift. How do I combat this? Is this detrimental only to performance or could it stress something mechanically? Thanks
Bad Andy
Bad Andy
My first night at the track after the 4.11 install, I got wheel hop on the 1-2, 2-3, and 3-4 shift. It was awful.
I kept dropping the tire pressure between runs and finally got the wheel hop to go away when I got to 24 PSI (Hot) on street tires.
I've got boxed LCA's being built by Spectacle Solutions right now.
Why would I relocate anything? the car is not lowered, I don't really know if changing the pinion angle is a good idea. Hey Roger, I like my Spec Solutions STB and if he wants to get some experimental LCAs out for testing, I'd be happy to try them out. Its nice to seem their line of products expanding.
Bad Andy
Bad Andy
Bad Andy
Bad Andy
This does NOT change the pinion angle at all.
The torque arm alone is the controlling factor for setting pinion angle.
Originally posted by Got-LT1
You meant 4.10s right? There are no 4.11s for the stock rear of a Camaro.
Yes, there are 4.11 gears made for the stock rear. I have a set of Motive 4.11 gears. I counted the teeth myself to make sure.
Motive makes a 4.10 gear set, made in the USA. Motive also makes a 4.11 gear set, made in Italy. However, I think they use the same part number.
Why did I get 4.11 instead of 4.10? 'Cuz that's what the shop had in stock the night I went in to buy my gears.
To the above question about 4.11s:
Not long ago on this board or ls1tech, someone proved that some Motive gears listed as 4.10s were actually 4.11s. It was said that the gears that were made in Italy were 4.11s and the gears made in the US were 4.10s. According to that info I have 4.11s. *shrug* I dare you to find a noticable difference.
edit: Yikes, you posted that ^ right before I did. lol
Originally posted by rncotton
Oh boy ... here we go again.
wytblur
Aug 5, 2002 02:03 PM
