whats the biggest size tire that will fit the stock LS1 16x8 camaro rim?
SLP sells the BFG Drag Radials installed on stock wheels - those are 255/50/16s - you should be able to fit at least that size.
It will effect your speedometer and gearing slightly of course, as you are going to a larger diameter tire.
Originally posted by stik6shift98
i dont think they make anything bigger then a 255 for a 16 inch rim.....u prob could fit a 275 but i doubt they make one
biggest is a 295/50/16 but noone sells them anymore a couple lt1 guys still run em but noone makes the tires anymore. realisticly i believe a 275/50 would be the biggest and best for contact but 255 is plenty on a 16" rim
Also, they must be bulging pretty badly over the lip of the rim...
TS
