What are the symptoms of a bad water pump?
Old Jun 24, 2003 | 08:14 AM
KASR_Z28's Avatar
I need to know what I can expect from a bad water pump - what are the signs?
KASR
Old Jun 24, 2003 | 09:29 AM
95GRNZ's Avatar
Arrow
I guess the only things that can really go wrong with water pump are gaskets and bearing.
If a gasket goes bad, that makes the coolant leak from the pump. If a bearing goes bad, it usually starts to make some noises.
TS
Old Jun 24, 2003 | 09:33 AM
KASR_Z28's Avatar
if it were bad, would the engine overheat immediately or slowly?
KASR
Old Jun 24, 2003 | 11:22 PM
Black01_Z's Avatar
a coolant leak and smoke coming from under your hood. Also a funny burning smell. In terms of how the engine would overheat it really depends on how much coolant your leaking. If its just a little then your engine is still running a lot of coolant and is cool. If your leaking alot then you dont have much coolant and will overheat extremely. If you ever see smoke coming from under your hood stop driving it and get it checked out.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
MattFick
Feb 15, 2015 10:16 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
