99 A4 dyno numbers?
99 A4 dyno numbers?
I went to the dyno today and i wasnt really happy with the results. I want to compare to other 98-99 A4s with relatively the same mods. All i have is a Lid and Cutout. There was no fan in front while i was on the dyno. Here are my numbers:
286.8rwhp & 301.6rwtq cutout capped
288.6rwhp & 297.8rwtq cutout uncapped
What do ya'll think? Thanks
I think you need to back there and tell the idiots running the dyno to throw a fan in front of your car!!! I have a 00' and my numbers were 296/310 stock. I havent been back since I got the mods done.
When I had mine dynoed, I got a 297 RWHP - I forget the torque off the top of my head.
( See http://web.camaross.com/forums/showt...threadid=46644 )
At any rate, I was not pleased w/ mine, either.
The prior owner had it dynoed at MTI (another shop in Houston) & got a 316 RWHP reading.
Different dyas, different machines, yada yada yada ...
Track Times are the real telling issue - not dyno numbers.
Now, if I can just find a day to make it back to the track ...
Oh, also bear in mind that the '01's & '02's got better intakes & cams, so if you are comparing yourself to a later model it's not exactly even.
We did, however , get the S.S. header style exhaust manifolds were the later cars got cast iron manifolds !!
Hope this helps !
Britt
Hope this helps !
Britt
When I only had a lid/filter my best was a 296/308. We did have a fan but I fail to seel how much of a difference that could make. But like NEWBIE T/A said, different dynos reactive differently and track times are what counts in the end.
Hey man I have a 99 trans am with pretty much the same mods as you. I had the same track times as you. Ran my car in 85 degree heat and 93% humidity and ran a 13.6 at 101 with a 2.1 sixty foot, so I tihnk I have a 13.2 or 3 in it when I get a 2.0 sixty and decnt weather. Also I ran the car after driving for an hour and a half no letting it cool off.
LID AND 3 INCH STRAIGHT PIPE AFTER CAT WITH NO MUFFLER 98 Z28 300 HP AND 328 FTLBS TORQUE A4
THAT WAS THE LAST RUN THE FIRST 2 WERE
295 HP AND 315 TQ
298 HP AND 326 TQ
THE FIRST RUN WAS RIGHT AFTER I DROVE 15 MILES TO THE DYNO SECOND RUN WAS ABOUT 2 MINUTES AFTER THAT AND THE THIRD RUN WAS AFTER A 30 MINUTE BREAK TO LET EVERYTHING COOL SOME BY THE WAY THEY HAD THE FAN RIGHT UP UNDER THE FRONT BUMBER POINTING AT THE RADIATOR THE WHOLE TIME. HOPE THIS HELPS
295 HP AND 315 TQ
298 HP AND 326 TQ
Weather REALLY affected my track times.
95 degrees 94% humidity gave me 13.669 @ 101.42 2.073 60'
69 degrees 50% humidity gave me 13.453 @103.52 2.029 60'
Car only has a K & N. All else is stock.
Sorry, no dyno numbers.
Thanks guys for all the replies. I have one other question, what is the proper way to dyno a A4 car? i am hoping the dyno was a little low. I was hoping for at least 300rwhp but i guess i need more mods. Thanks again.
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
